Re: A cylinder 2 and 3 not firing
Bob
05-11-2008 12:49:26
Try swapping those 2 spark plug wires, in case you've got the firing order WRONG.
If NOT, the head gasket MAY be blown between #2 and #3 cylinder.
1fortyfanatic
05-12-2008 20:00:39
 Re: A cylinder 2 and 3 not firing in reply to Bob, 05-11-2008 12:49:26
[quote="francoisc27"](quoted from post at 03:14:55 05/13/08)
Good luck francois, and I surely do hope that when that head comes back, it's just a gasket you need. Oh, and as for the disagreement, like I said, don't be sorry, not your fault at all. These things don't normally happen around here. :oops:
Dave
ih560
05-11-2008 17:02:37
If it is cylinder 2 and 3 then I doubt it is a manifold gasket problem. I would be more likely to believe it is a manifold gasket problem if it were cylinder 1 and 2 or 3 and 4. Cylinder 2 and 3 do not share a port like 1 and 2 or 3 and 4 would. Sounds like your valves are out of adjustment or you just plain have bad spark plugs or wires. If you plugs and wires are old, go ahead and change them and see if that helps. If you are getting fire at all cylinders and it is still missing on 2 and 3 then take the valve cover off and set the tappet gap to .014 hot. If you can not get it running good enough to warm it up the way it is, then set the gap to something like .017 cold and then start it. Let it run long enough to warm the engine (don't run it really hard or anything just yet). Once you get it warm take the valve cover back off and set the gap to .014. That should get you going. I have had the same thing happen on customers tractors before.
Hope this helps
Dustin Moran
Farm Parts And More
(859) 433-5798
francoisc27
05-11-2008 12:51:51
[quote="Bob"](reply to post at 15:49:26 05/11/08) [/quote
already tried swapping plugs just in case....
If I take the head off to look, do I have to replace the gasket or can it be reused?
Bob
05-11-2008 13:42:04
 Re: A cylinder 2 and 3 not firing in reply to francoisc27, 05-11-2008 12:51:51
NO NEED to tear into it just yet!
Check your compression.
If the gasket IS blown between 2 and 3, 2 and 3 will have little or no compression. If their compression is up there with 1 and 4, the gasket is NOT blown.
