Re: A cylinder 2 and 3 not firing
francoisc27
05-11-2008 14:02:10
Bob said: (quoted from post at 16:42:04 05/11/08) NO NEED to tear into it just yet!
Check your compression.
If the gasket IS blown between 2 and 3, 2 and 3 will have little or no compression. If their compression is up there with 1 and 4, the gasket is NOT blown.
I am gonna try and borrow a compression tester from my neighbor, I had a nice one, but it got stolen:-( I'll try it and get back..Thanks Bob
1fortyfanatic
05-11-2008 16:15:37
 Re: A cylinder 2 and 3 not firing in reply to 658834, 05-11-2008 14:02:10
Just FYI, you might want to consider checking around the manifold while it is running to see if the gasket there is possibly a problem. If the manifold gasket on an A is like my 123ci Farmall 140, then the manifold has intake and exhaust side by side. And if the gasket has blown between almost any two of the ports, then you could be getting exhaust in the intake of the neighboring cylinder, in which case, valves will not function properly, and plugs would probably look dry. Be advised though, that if you pull the manifold, you'll probably lose one or both of the old gaskets, so order new ones before you ever pull it. Case / IH dealers can order these gaskets for you, and have the shipped to your house in 3-5 days.
Good Luck
Dave
