in a pinch could a fellow
tn terry t
05-11-2008 16:46:23
i need to get in the hayfield cant get the brother-in-laws to agree as to how to repair the 560 hitch problem so the heck with them. in a good flat field with grass hay at just over waist high can i get by pulling our 472 haybine with a h? i have my 3000 ford with a 6 ft. drum mower but i have about 50 acres needing cut right now i work full time so i need as many tractors in the field as i can get
Steven f/AZ
05-14-2008 07:10:16
 Re: in a pinch could a fellow in reply to tn terry t, 05-11-2008 16:46:23
Might not go as fast, but it will pull it!
Bill46
05-14-2008 06:40:26
Think about putting an overrunning pto extension on it. Don't ask me how I know.....
Allan In NE
05-12-2008 04:18:23
Terry,
Mowers aren't like tillage implements in that they just don't load the tractor all that much. If it will pull it across the yard, it will pull it in the field.
I've cut thousands of acres of heavy alfalfa with a 9' swath using a H.
Hook 'er up and go. The only problem you're gonna have is that lift cylinder; gotta rig 'er for one-way use with the H.
Allan
ihc49
05-11-2008 21:38:16
why dont you hook up and tell us if your H handles it .you got the tractor so try and see.
MN Scott
05-11-2008 20:34:57
A H should pull it just fine. My dad and uncle cut hay for years with Super H's pulling 9 ft New Holland haybines. Never had a problem and always run in third gear.
tn terry t
05-11-2008 19:55:47
 Re: in a pinch could a fellow in reply to 658834, 05-11-2008 16:46:23
GordoSD said: (quoted from post at 22:44:45 05/11/08) Buy an M real quick and dump the H
Gordo
i dont think so aint enough money to make me part with this ole h besides if if i was gona trade for more hp. i dang sure wouldnt looking for a m :wink:
GordoSD
05-11-2008 19:44:45
Gordo
Ozarker
05-11-2008 19:33:58
An H farmall will handle a 7' haybine just fine. Dad bought one of the first 7' machines that New Holland made. We cut enough to bale 12,000+ squares per year. The machine was traded on a 488 Haybine when the sheet metal between the sickle and the rollers wore thru. The 488 (9'cut) needs 40-45 hp in a good crop.
tn terry t
05-11-2008 18:21:24
thanks rusty i guess i really knew the answer to begain with :cry:
RustyFarmall
05-11-2008 18:03:26
I don't think your H has enough horses to handle it unless the hay is extremely light.
