Super H Hydraulics
GordoSD
05-11-2008 17:36:42
I thought I could save a little fuel and palnt corn and sorgham with my JD 7000 4RN palnter using the SH rather than the 966. Hooked up the palnter to the SH and gave it a test run. It won't raise the planter to the full up position. The 966 "bangs it full up, the Sh gets it about 2/3 up, piston about 4 inches out.and the markers work perfectly. It's a 5 inch cylinder. Fluid level checked and topped off. Is this normal?
tn terry t
05-11-2008 20:38:29
 Re: Super H Hydraulics in reply to GordoSD, 05-11-2008 17:36:42
hey Gordo maybe you need to buy a super m real quick and dump that super h :)- - - - -GOTCHA! :wink:
GordoSD
05-12-2008 04:57:47
 Re: Super H Hydraulics in reply to tn terry t, 05-11-2008 20:38:29
SMTA sitting in the shop, doing a full resto on that. Just tin work left. :)
Gordo
MN Scott
05-11-2008 20:28:12
Belly pump or live engine driven pump? A engine driven pump should pop up a full 4 row 7000 no problem. A belly pump if worren might have trouble. My dad planted corn for years with a 7000 4 row with a 53 Super H with belly pump. It would lift a full planter but you had to stop at the headlands shift to N and rev engine to lift it. Also in the hills in soft soil it would slip pretty good.
GordoSD
05-12-2008 05:02:44
 Re: Super H Hydraulics in reply to MN Scott, 05-11-2008 20:28:12
It's a Stage II, 1954, last week of production.If it won't do this job, it's going down the road!
Gordo
BOBM25
05-12-2008 12:37:58
 Re: Super H Hydraulics in reply to GordoSD, 05-12-2008 05:02:44
Let me know if you decide to send it down the road.
Janicholson
05-11-2008 17:44:18
A 6" cylinder would make it go. Spring assist? JimN
Steven f/AZ
05-11-2008 17:39:02
Our Super MTA wouldn't raise our 400 cyclo planter with the fertilizer boxes loaded up.
I believe a Super H is limited to about 1000 or 1200 psi...
GordoSD
05-11-2008 19:25:57
 Re: Super H Hydraulics in reply to Steven f/AZ, 05-11-2008 17:39:02
Just had the seed boxes 1/4 full, and the fertilizer boxes 1/8 full. Maybe I can live with dragging the seed discs in the ground on turns? Besides, it looks like a lot of weight on the drawbar. Moved the planter up to the horizontal bar from the swinging bar and the front went down a couple of inches/
Gordo
