404 fuel problem
alex genty
05-11-2008 20:06:38
Howdy y"all! I"ve got an IH 404 with an odd fuel problem. I just replaced the fuel filter with a new one from NAPA and now my tractor acts as though it doesn"t get enough fuel and it will run for a while, then die. Also, I noticed that after I shut it down (or after it dies) gasoline drains from the bottom of the carb. there are 2 bolts on the bottom(underside) of the carb...it never did this before! Is there a correct fuel filter for my tractor? Should my carb drain like this? HELP!!!
IH2444
05-12-2008 05:54:29
 Re: 404 fuel problem in reply to alex genty, 05-11-2008 20:06:38
No you carb should not drain like that. Sounds like you need to clean the carburator out. It probably has bits of debris in the float valve and main jet.
