paint
poorfarmall 1
05-12-2008 16:43:57
just wondering if tractor supply paint is any good. thanks
mark jr
05-14-2008 05:28:52
 Re: paint in reply to poorfarmall 1, 05-12-2008 16:43:57
i cant see that the tsc paint is bad but when i use it i clear coat over it
WHISKEY BENT
05-12-2008 19:23:27
USE HARDNER WITH WHAT EVER PAINT YOU USE. IT WILL SHINE BETTER, CURE FASTER, AND IT WONT FADE QUITE AS FAST. I USE DUPONT CENTRI FOR SHEET METAL AND VANSICKLE FOR CASTING. GOOD LUCK!
CNKS
05-13-2008 05:02:14
 Re: paint in reply to WHISKEY BENT, 05-12-2008 19:23:27
You are using the best acrylic enamel available (Centari) and the worst alkyd enamel (Van Sickle). Perhaps the fading is less noticeable on the cast.
GordoSD
05-12-2008 19:14:02
No, JUNK.
Gordo
CNKS
05-12-2008 17:11:30
It is the 30's alkyd enamel, it will fade if left outside. Kept waxed it may be ok, but you get what you pay for. If you want a somewhat better paint that doesn't cost an arm and a leg, get IH 2150 from your Case-IH dealer.
