H trans leaking
Lon-Mo
05-13-2008 12:44:37
Want to fix up my H. Plan to start with a leak in the transmission. Oil is dripping out about 2 ft. in front of the rear axel. There is a drain plug and a metal plate about 8x6 in. Oil is dripping near here. Drain plug not leaking. Any comments appreciated. Lots of info. on this site.
Thanks, Lon.
Michael Soldan
05-13-2008 15:12:51
 Re: H trans leaking in reply to Lon-Mo, 05-13-2008 12:44:37
Take that plate off, you will see two shafts that drive the trans and the belly pump, getting the pump out is a bit difficult, remove the bolts in the shaft and set it aside. Turn the flange where it is leaking out, counter clockwise, pick out the seal and tap a new one in place and reassemble..a few hours on Saturday morning and its done...lots of H's don't leak until the trabs is properly filled and then they leak..very common...as stated , check the archives, all the info you need to fix the problem..couple of hours at the most
neblinc
05-13-2008 14:06:21
Oh and welcome to the YT forums!!
And if you are from Missouri mark your calendar for RPRU
Randy
neblinc
05-13-2008 14:01:31
Check my pics here
3 common places they will leak, belly pump seal, belly pump drive seal & transmission drive seal.
Not to hard to fix, just a messy dirty job :wink:
Randy
Coax
05-13-2008 12:58:41
Look at the top of this page,hit Search,and type in "Rear axle Repair" or any combination of words and all your dreams will come true.....
Peace. :)
