bad bull gear ???
gmsupera
05-13-2008 17:00:05
my 51 super a has started making what sounds like a bearing noise plus a loud clunk every time the bull gear makes one complete rotation;it goes around and clunk goes around and clunk do you think that I have broken tooth its on the left side I havent taken the housing pan off yet I will be off the post for awhile so any thoughts would be helpfull thank you for your time. by the way it does it out of gear with engine off going down a slight hill
Janicholson
05-13-2008 17:31:14
 Re: bad bull gear ??? in reply to gmsupera, 05-13-2008 17:00:05
if you think they are tight, put a dab of nail polish on the joint between the wheel and rim. let it dry (or shake it out the car window) and then drive it. if the polish is broken (oh no a broken nail) it is not tight, and might need rethreading and or a new bolt (use locktite on the bolt threads, and tighten 1/8 turn from twisting off (joke). Use the specifications! JimN
Hugh Mackay
05-13-2008 17:26:24
GM: I agree with CNKS, check those wheel first. Don't do it just by sight, put a wrench on the nuts.
CNKS
05-13-2008 17:20:00
Could be, but first make sure the rim nuts are tight.
