560D TA slipping
scenic acres
05-13-2008 18:56:03
I recently had to replace the TA clutch, pressure plate, and throwout bearing. The bearing was completely gone and wore grooves in the pressure plate. Well the TA worked fine for a while and now when I pull the lever back it slips. You can apply the brake and it does not go anywhere. As I allow the lever to move foward the tractor takes off or if i hold the brake enough it will kill the engine. What should I do, is it just out of adjustment?
TractormanNC
05-13-2008 19:28:03
 Re: 560D TA slipping in reply to scenic acres, 05-13-2008 18:56:03
The one way clutch (sprag) is toast. Should have replaced it while you were in there.
scenic acres
05-14-2008 03:49:10
 Re: 560D TA slipping in reply to TractormanNC, 05-13-2008 19:28:03
I replaced the entire clutch and presure plate assembly, throw out bearing, the seal in the TA. Where is the one way clutch (sprag) located?
Kevin Meier
05-14-2008 13:53:46
 Re: 560D TA slipping in reply to scenic acres, 05-14-2008 03:49:10
It"s not actually a sprag unless it"s an aftermarket heavy duty. It"s a ramp with 8 rollers. You need to pull the t/a out and split it in half just above the 4 bolts that hold the ramp in. I have replacement parts if you are interested feel free to email me.
kevin
Kevin Meier
05-14-2008 17:58:42
 Re: 560D TA slipping in reply to Kevin Meier, 05-14-2008 13:53:46
go to the cnh website search for 560 parts it's under rear frame and driving mechanisms 152. When the picture comes up the ramp is part #11 the actual part number is 365402R11.
scenic acres
05-14-2008 17:03:05
do you have a drawing showing the location of this area?
Kevin Meier
05-14-2008 18:04:07
 Re: 560D TA slipping in reply to scenic acres, 05-14-2008 17:03:05
when you get the t/a out you may need to also machine your ramp roller surface on the 361281 carrier. And also the seal surface just under the t/a flywheel splines. With a .010 oversized roller the ramp area should measure 2.858 or higher and the seal surface should measure 2.933 or higher. Any other questions my email is open.
Janicholson
05-14-2008 06:43:11
It is on the other (transmission) end of the TA.
JimN
