M w/live hyd advise please
ch0ck 430 C
05-13-2008 19:55:22
I just got done adding live hyd to my Farmall M. I used the IH add-on 2way tree valve like this.
third party image
My question is: Do I need to add a pressure regulator or will be ok without?
Steven f/AZ
05-14-2008 07:07:36
 Re: M w/live hyd advise please in reply to ch0ck 430 C, 05-13-2008 19:55:22
Super M and up were rated for 1200 psi, I believe.
Chuck46
05-14-2008 08:27:53
 Re: M w/live hyd advise please in reply to Steven f/AZ, 05-14-2008 07:07:36
Steven, I&T Shop Service manual says 1000, Chuck
Chuck46
05-13-2008 20:35:11
Chock 430 C, Those valves do not have a relief valve in them so yes you have to put one in between the pump and valve. Good luck, Chuck
ch0ck 430 C
05-13-2008 20:48:49
 Re: M w/live hyd advise please in reply to Chuck46, 05-13-2008 20:35:11
I knew it didn't have the relief, just wasn't sure if the pump was capable of enough pressure to warrant one.
Chuck46
05-13-2008 20:53:50
 Re: M w/live hyd advise please in reply to ch0ck 430 C, 05-13-2008 20:48:49
Oh yes any good pump will ruin itself or the gears that drive it, they will kill an M. Chuck
ch0ck 430 C
05-13-2008 20:59:56
 Re: M w/live hyd advise please in reply to Chuck46, 05-13-2008 20:53:50
What psi should I set it at, once I get it? I already have the 400 cam gear put in.
Chuck46
05-13-2008 21:06:14
 Re: M w/live hyd advise please in reply to ch0ck 430 C, 05-13-2008 20:59:56
The SMTA with that pump and valve were set at 1000. I have my H at 1000 also it does well on the work I use it for and has run for 35 years with out any problems. Chuck
ch0ck 430 C
05-13-2008 21:15:33
 Re: M w/live hyd advise please in reply to Chuck46, 05-13-2008 21:06:14
Sounds like a plan. Now to go find a relief valve to put on it.
Chuck46
05-13-2008 21:17:58
 Re: M w/live hyd advise please in reply to ch0ck 430 C, 05-13-2008 21:15:33
Do you have a Northern Tool close by, Chuck
ch0ck 430 C
05-13-2008 21:21:56
 Re: M w/live hyd advise please in reply to Chuck46, 05-13-2008 21:17:58
I'm not sure but was looking at them online. They had one I liked.
