Clutch on Farmall C
Russell J
05-14-2008 12:03:31
Almost iomediately after running a grain auger last fall, my C won"t go into gear. It grinds on the gear. Is my clutch out or what? I tried to adjust in the belly with no results. No prior signs to any problem until we finished.
FromJB2
05-14-2008 18:01:50
 Re: Clutch on Farmall C in reply to Russell J, 05-14-2008 12:03:31
Hi Russell, another possibility could be the pilot bearing in the flywheel. On the C & SC it was just a bronze bushing that would get clogged with clutch dust and bind on transmission shaft. This would cause transmission shaft to turn even though clutch was depressed. There was no method of lubrication, so to fix requires splitting the tractor.
JimB
El Toro
05-14-2008 13:02:47
Have you put it in gear, then started the engine or bumped the engine with the clutch depressed? If the tractor moves the the clutch disc may be stuck to the flywheel and not releasing. Hal
El Toro
05-14-2008 13:02:33
El Toro
05-14-2008 13:02:22
