 I got this a couple days ago, and I'm trying to figure out exactly what I have. I made up a little web site with pics.(link below) From the sn (738) this appears to be a 1963, and the 237th 806 made (they started with 501). Can anybody tell me if this is at all rare? Obviously 806's are everywhere, but you don't see a lot of International 806's that are not wheatlands, do you? Are those the right fenders? They look like they go on a Farmall 806- I think this had the round fenders. I'm in the market for: -grill, -large "international" hood emblems, -ether injector, -seat, -steering knuckles, king pins (they have been welded, various steering components-the steering is very sloppy -parking brake not working -Tach not working- maybe send out for rebuild? -TA not working- to expensive to fix ALSO- There is no charging system installed at the moment. The former owner installed 2 12 v batteries on the assumption that it was a 24v system. I don't think this is right. The original generator is gone, and a delco alternator is there, not wired up. He did however give me a John Deere 24v generator and voltage regulator. So- since those batteries are nearly new and expensive (John Deere strongbox), I think I might wire up the 24v generator. None of the instruments work, or are disconnected. Clearly, I'll have to wire them to one of the batteries to get 12v. A real fixer-upper! I don't plan to make it a show tractor, but I'd like to fix much of this and use it on the farm. The engine is fine (a little blow-by out the bottom- not bad). Gears all seem fine. Clutch decent. What can you guys tell me about this?
