W4 engine-will engine from 91 combine fit
RVS
05-16-2008 05:52:44
Hello Gentlemen. We are starting our new 4H project this year,it is 1952 W4 donated by a local farmer. When he told us that we could have it he said the shifter fork was broken and that is all it should need, except for a few little things.We went to drain the rad last night and it only had a few ounces of fluid. We thought that it might have been drained. When we went to drain the engine oil we found the coolant.After speaking to the farmer he told us that the engine had a cracked block in it years ago and he had sealed the block and installed a new sleeve in it and had no problems. The tractor has been sitting for 10 years in the work shop waiting for the trany work.One of the fathers said he has an engine out of a 91 IH combine we can have for it .Does anyone know if the engine will fit without too many changes?
Thank you for your help
Charles E. McNelly
05-16-2008 12:53:06
 Re: W4 engine-will engine from 91 combine fit in reply to RVS, 05-16-2008 05:52:44
Find an engine out of a 300 or 350, alot more power and there a bolt in. I always wanted a W-4.
Good Luck,
Charles
El Toro
05-16-2008 07:39:29
It used the C135 engine. Hal
h-elp
05-16-2008 10:21:39
 Re: W4 engine-will engine from 91 combine fit in reply to El Toro, 05-16-2008 07:39:29
why do yu always say Hal behind your post, whats it mean, just wondering,
El Toro
05-16-2008 11:27:28
 Re: W4 engine-will engine from 91 combine fit in reply to h-elp, 05-16-2008 10:21:39
That's my name shorten some. Hal
Harold H
05-16-2008 07:21:54
It will not just bolt up. If you MAKE it fit, you will have a underpowered W-4.
Harold H
Hugh Mackay
05-16-2008 06:27:03
RVS: I'm not sure which engine a 91 combine had, but it's certainly no W4 C-152 engine. Probably a C-135 maybe even C-123. Even if it's a C-153 it's not going to develop the hp and torque of a C-152. You'll most likely have problems with pilot bushing or bearing and front engine supports.
goforit
05-16-2008 06:00:59
yup, go for it ,your 91 may have hydraulic pump which will be a plus if you want that.
