Distributor Drive Gear??
K-Mo
05-16-2008 08:51:55
I need a distributor drive gear for an IH distributor. I went to CaseIH and they convert the IH 353902R1 to 531461R91 which is a drive gear package for a Prestolite distributor.
Are the IH drive gear and Prestolite drive gear package interchangeable?
K-Mo
Hugh Mackay
05-16-2008 16:57:56
 Re: Distributor Drive Gear?? in reply to K-Mo, 05-16-2008 08:51:55
K-Mo: Last year I picked up a used set of drive gears for my 130, $35. I asked for and got a matched set from a donor tractor. I think it is quite important you either go new with both gears or find a matched set of used. The gears I got were like new. My e mail is open, if you wish to know more.
MAGMAN
05-16-2008 14:04:58
I have a brand new one here for an IH? JON
Nebraska Cowman
05-16-2008 09:47:20
Boy, I don't know. If the shaft is the same size (which is very possable) it would likely use the same gear. I'll go out and look and see if I have any gears
