Need a part for a Super A
DLJ in NC
05-16-2008 10:47:42
Hello,
Not sure where else to find the part I need. I need the piece that connects the lifting arm to the rockshaft. Looks like a circle that slides over the rockshaft with a bolt attached that bolts thorugh the lifting arm. Can anyone lend some assistance. My email is cejdlj@yahoo.com
Thanks,
Donnie
Daniel H.
05-17-2008 17:18:48
 Re: Need a part for a Super A in reply to DLJ in NC, 05-16-2008 10:47:42
515 226 R91 is for the smaller rod, the tractors without fast hitch. You have to look in the implements part manual instead of the tractor manual. The rear rock-shaft and linkage is considered a " common unit" and was sold with an implement.
Daniel H.
05-16-2008 18:16:51
The part you need is 515 226 R91. It is still a good number from CNH but is its $86.00. Depending on where you are in NC you might try SA Fitts in Danville, VA.
ScottyHOMEy
05-16-2008 12:38:50
Try Glen at Little Red Tractor Company.
DLJ in NC
05-16-2008 12:15:20
Dave,
didn't find the exact part number, but the part manual is showing a super A from 1953 as having a fast hitch. The part that is very similar and would probably connect my lifting arms is the 520066R1 PIVOT TRUNNION, lift link. Hope this helps sort it out.
Donnie
SuperA-Tx
05-16-2008 20:33:57
 Re: Need a part for a Super A in reply to DLJ in NC, 05-16-2008 12:15:20
Donnie,
Im not positive on this but what I know on my SA and our 140's is that the lift link is a bigger rod when you have the fast hitch and thus the pivit trunion would be larger.
If yours didnt come with a fast hitch your rod is probly around 3/4" outside diameter and if it came with a fast hitch it is probly around 1" diameter.
I bet that little part might be hard to find if it fits on the small rod. You might see if someone can fab you one, it isnt that complicated of a part.
Dave Sherburne NY
05-16-2008 11:09:58
Not sure what you mean so you will have to look it yourself
Link
