Order Farmall Cub Parts Online
Cub 1948 clutch
Lucien Cyr
05-16-2008 15:23:57
Well I just put a new clutch, pressure plate, bearing and a bushing. When I push the clutch pedal to disengage, the side of the bearing touch the clutch finger and make a loud noise. I suppose I have to adjust the clutch finger. Is this something I can do from under, by the round hole or do I have to remove the pressure plat to adjust.
Lucien Cyr
05-17-2008 07:37:52
 Re: Cub 1948 clutch in reply to Lucien Cyr, 05-16-2008 15:23:57
I split the tractor and ajusted the fingers, work like new.
John M
05-16-2008 16:55:38
 Re: Cub 1948 clutch in reply to evilboweviel, 05-16-2008 15:57:09
You must have small hands? I tried it that way once. I think it was faster for me to slit it again, but I also didnt have everything 100% buttoned up either.
