IPTO for a SMTA?
Cub n M in OR
05-16-2008 21:10:43
I'm thinking of going to look at a SMTA that is for sale about 3hrs away. Talked to the seller, he says there is a plate where the PTO should be. The serial # has the "S" which I think means it was set up for the IPTO. So now the questions. How hard is it to find a pto unit to put in it? How tough is it to install? If it had one originally, what would have motivated the guy who owned it at the time to take it completely out? What kindof trouble could I be getting myself into?
Only reason I'm considering this tractor is that they are few and far between here on this side of the Rockies, and it's fairly cheap. Thanks for the insight.
Ben
Hugh Mackay
05-17-2008 02:28:05
 Re: IPTO for a SMTA? in reply to Cub n M in OR, 05-16-2008 21:10:43
Ben: The PTO unit shouldn't be too hard to find, that same unit was used on 300, 400, and most 350 and 450. They show up ocasionally here in classifieds.
If your tractor has the internal PTO driveline from flywheel back. All you need is the unit and coupler shaft. When I say coupler shaft, there is a short shaft splined and couplers for each end. That short coupler shaft will not be in tractor, PTO holds it in place. I know this as PTO went in my 300. We removed unit and short shaft put a plywood cover over hole and continued to haul wagons with it. That short shaft may be your kicker. While actual unit is the same, that shaft is different length in the smaller chassis 300 and 350. I Think I'm right, however it's been a few years since I dealt with this, I had both large and small chassis tractors. I do know we had PTO from 300 in a large chassis tractor.
kossuth
05-17-2008 05:24:10
 Re: IPTO for a SMTA? in reply to Hugh Mackay, 05-17-2008 02:28:05
Hugh Mackay said: (quoted from post at 02:28:05 05/17/08) Ben: The PTO unit shouldn't be too hard to find, that same unit was used on 300, 400, and most 350 and 450. They show up ocasionally here in classifieds.
Your list of possible donors would also be the 300 utility tractors plus the 460 and 560. Very very common PTO setup used throughout the late 50's early 60's by IHC
