H 3 point hitch installed!
Bob Kerr
05-17-2008 06:13:06
Well most of the way, still have to get the plumbing done. The Saginaw hitch bolted right up and outside of being 400lbs heavy, it went smooth. Sure looks slick so far!
Tom Windsor
05-17-2008 18:08:13
 Re: H 3 point hitch installed! in reply to Bob Kerr, 05-17-2008 06:13:06
I installed one of their hitches on my H. I have been real tickled with it. As you said, it lifted right in place. I had a hoist to set it by myself as it was so heavy. The plumbing is easy. The line from up front to the rear I used a braded hose there and routted it under the tractor to the rear. I put a "T" in the back and then some regular lines to each cylinder. You are going to be pleased with this arrangement.
Tom Windsor.
