farmall h shifting problems
david mccord
05-18-2008 06:01:26
Having problems shifting out of first and reverse gear,other gears shift fine.
Don L C
05-18-2008 07:26:16
 Re: farmall h shifting problems in reply to david mccord, 05-18-2008 06:01:26
david ---
Before you pull the top cover (heavy),knock the pin out of the shift lever (put it in nutrial) first...lift lever out,bottom of lever should be about 1/4" wide and 5/8"long no groves.....look where it fits and build it up with welder and grind it to easy fit.....
Now that I have started this I cant remember to well, its been a while..... somebody else will help..... .Don
Bob Kerr
05-18-2008 06:16:24
May have a bent shaft or the splines may have a grove worn in them, but since you have first and reverse acting up I would say it is the shaft bent. There also could be a problem with the slide mechanism for those gears. Sounds like you may have to pull the top cover to check everything.
Bob Kerr
05-19-2008 18:07:03
 Re: farmall h shifting problems in reply to Bob Kerr, 05-18-2008 06:16:24
I will add I replaced the shifter in mine yesterday. It shifted fine in all gears but the lever was sloppy and if you shifted too fast you could get it locked in 2 gears at the same time. The end on mine was worn out. If the tractor you have was used a LOT in low gear and pulled very heavy loads, It could have a grove worn in the shaft where first gear slides.
