Rockshaft Pin Measurements
Cmore
05-19-2008 06:13:22
Does anyone know the length and diameter of the small "pins" that go in the rockshaft "arms" of a Super C? These are used to attach the cultivator and I keep loosing mine...need to take them out when not in use, I guess...thanks, Cmore
Hugh Mackay
05-19-2008 08:35:24
 Re: Rockshaft Pin Measurements in reply to Cmore, 05-19-2008 06:13:22
Cmore: Those are not a standard size your going to find in any bolt shop. If you go to CaseIH you'll find they are close to gold in value. If they are not in use, it's best to remove them. The most common reason for them going missing is the value. Hands that remove them, should wacked with a hammer during the theft. Do you ever leave your tractor where there is opportunity for theives?
SuperCmore
05-19-2008 10:13:21
 Re: Rockshaft Pin Measurements in reply to Hugh Mackay, 05-19-2008 08:35:24
Yes, it would be fairly easy for someone to swipe them if they were amind to...Thanks, Cmore
Coax
05-19-2008 10:54:23
 Re: Rockshaft Pin Measurements in reply to SuperCmore, 05-19-2008 10:13:21
I had to Have a Machinist spin me up some replacements for mine... I used my last real one for a pattern....made 6 for about 75$ (plus free replacements for future losses) :(
