Disk Repair
Tom P
05-19-2008 08:56:41
Any advice or tricks to replacing broken discs on an IH 410 field disk?
GordoSD
05-19-2008 10:57:45
 Re: Disk Repair in reply to Tom P, 05-19-2008 08:56:41
You'll need two pipe wrenches. Ones about 32 inches long! Squirt everything down with loosenall today, and wait a day before you start to work. I just had to replace a spoll on my JDAW16. Of course it was the one farthest form the end nut. I took 90% of the old bolts,wshers, nuts, to the IH dealer and went through his new bolt bins and replced them.
Gordo
the tractor vet
05-19-2008 10:31:19
Well a big chain wrench and correct socket and at least a 3/4 impact but a 1 inch drive is better keep all parts in order as they came off loosen up the brackets to the main frame when ya go to tighten up the gang and when you think that you have everything tight tighten some more. Rebuilt a bunch of disc's over the years and it is nothing but hard work.
