MCV pump
nates90
05-19-2008 11:32:38
Wondering if you guys would think my MCV pump is getting weak. When i was planting for awhile...when i would idle it down.....and then push on the brakes..the low oil pressure light would go on...i know the front cooler is working, but just wondering if maybe the pump is getting weak. When it is cold...it seems to work fine.
Allan In NE
05-19-2008 11:42:11
 Re: MCV pump in reply to nates90, 05-19-2008 11:32:38
Idle down? Thought you were using a Cyclo?
Allan
nates90
05-19-2008 13:42:17
 Re: MCV pump in reply to Allan In NE, 05-19-2008 11:42:11
Yea, I am, but this is when i was all done and getting ready to park it for the night, i would be sitting there on idle and push the brakes, and the light would come on.
the tractor vet
05-19-2008 14:20:39
 Re: MCV pump in reply to nates90, 05-19-2008 13:42:17
YEP , it's time . But there are other things that can also cause a loss of flow . The pump is the cheap way out. and if this does not solve the problem then it is time for a T/A . But i do not know how your tractor acts when you are running it . To run a test on the MCV ya need a couple gauges and a Flow Rater . Then you can say for sure.
