Charrlynn power steering question
Redstate
05-19-2008 13:06:09
Hi, just wondering if the belly pump on an M would power the ps and how many PSI is actually needed for a Charlynn PS torge Generator. Thanks
Mike L
05-19-2008 18:32:03
 Re: Charrlynn power steering question in reply to Redstate, 05-19-2008 13:06:09
I used a pump off a 1977 olds cutlas it works great.
gene bender
05-19-2008 17:35:11
Just get the seperate pump for the power steering then you dont need to divert the hy supply and all that mess. It will work just fine.
Allan In NE
05-19-2008 16:03:19
Yeah,
It'll work right until the time ya push the clutch.
Allan
Steven f/AZ
05-19-2008 14:14:24
I believe the max pressure for the torque generator is 1000 psi.
A good belly pump (later model) will have 850 psi. The belly pump will work fine for power steering, but don't expect to lift/lower implements and steer at the same time, even with a flow divider. The GPM of the belly pump is a little short to run multiple things at once.
