Order Farmall Cub Parts Online
Inhaling exhaust on cub?????
Mifsud
05-20-2008 17:47:16
Friend of mine brought over a cub he just came by. Could not get it to start. Had spark to plugs. After a few attempts we noticed that the exhaust was sucking in air instead of putting out exhaust air. Can't figure out what causes this problem and how to correct it. We know the fellow who had it before had replaced the head gasket and also switched from a mag to distributor set up. Still 6 volts. He never did get it running. Any ideas to what is going on and how to correct will be appreciated.
john *.?-!.* cub owner
05-21-2008 19:58:19
 Re: Inhaling exhaust on cub????? in reply to Mifsud, 05-20-2008 17:47:16
exhaust valve sticking open.
gene bender
05-21-2008 03:19:01
What is the compression readings. You will need to see in the cycl thru the spark plug hole as it sounds like you have to start from the first square as lots of things could be out of whack. With the side panel behind the carb off you can see the valve movement.
teddy52food
05-20-2008 18:16:30
Camshaft is a half a turn off.
Owen Aaland
05-22-2008 03:23:45
 Re: Inhaling exhaust on cub????? in reply to teddy52food, 05-20-2008 18:16:30
teddy52food said: (quoted from post at 18:16:30 05/20/08) Camshaft is a half a turn off.
The camshaft rotates at half of crankshaft speed, so as long as the timing is correct in relation to the camshaft, you cannot be half a turn off on the camshaft.
Scott Rukke
05-20-2008 18:02:19
Take off the valve cover and check the valve adjustment. Also check the firing order and timing.
gene bender
05-21-2008 03:13:45
 Re: Inhaling exhaust on cub????? in reply to Scott Rukke, 05-20-2008 18:02:19
Valve cover on a CUB.
Jim in Ma.
05-21-2008 05:13:22
 Re: Inhaling exhaust on cub????? in reply to gene bender, 05-21-2008 03:13:45
Yes = on the side , behind the manifold.
