Farmall A S/N
Ron in OH
05-20-2008 18:17:32
1940 model A with sn FAA 21680 with hand crank start. Does one of the "A's" in the SN represent a hand crank model ?
gene bender
05-21-2008 03:04:59
 Re: Farmall A S/N in reply to Ron in OH, 05-20-2008 18:17:32
No all As had FAA as a prefix to the number.
Dave BN
05-20-2008 22:37:51
Yep, looks like 1940 A. If no starter then most likely you don't have a choke rod that goes back to the operators area either. With magneto ignition these tractors are easy to start with the crank if the timing is set properly. Dave
Athol Carr
05-20-2008 18:33:04
No, the FAA is Farmall A and carried on to cover the Super A. A Farmall B would have serial number prefix of FAB. In the first Farmall A and B tractors there was no provision for a starter, a Bosch no battery generator could be supplied to drive lights for the lighting attachment
Red Mist
05-20-2008 18:28:11
No. "FAA" is just the prefix for all A and SA tractors. mike
