Adjusting front end on IHC 140
Chuck Edler
05-20-2008 18:53:41
This wide front end is set at 40 inches. I have moved the front and rear tires to 56 inches.
My problem is connecting the front tie rods. Do I have to switch them to obtain the necessary width for 55 inches.
Thank you chuck
Hugh MacKay
05-21-2008 02:07:17
 Re: Adjusting front end on IHC 140 in reply to Chuck Edler, 05-20-2008 18:53:41
Chuck: No: there is the same coresponding adjustment on tyrod as on the axle. If you have two holes exposed on the telescoping axle then you must have two exposed notches on tyrod. Same with 3 and 3 .
Your suggestion of 55" is technically 56. Sounds to me as though you may have it set at 52" on front, with front wheels dished out.
