340 blowing oil
Mark W.
05-21-2008 09:06:54
My gas 340 blows a little oil out of the exhaust on initial start up. I checked all levels and replaced the oil in the air filter cannister. It has good power and doesn't smoke when working. Compression also seems to be fine. Any thoughts would be greatly appreciated. Thanks
Bill Lisbon
05-21-2008 09:12:18
 Re: 340 blowing oil in reply to Mark W., 05-21-2008 09:06:54
Oil could be coming thru valve guides. Check valve seals on intake valves.
Mark W.
05-21-2008 09:19:40
 Re: 340 blowing oil in reply to Bill Lisbon, 05-21-2008 09:12:18
Thanks, that's where I'll go next!
Janicholson
05-21-2008 16:19:34
 Re: 340 blowing oil in reply to Mark W., 05-21-2008 09:19:40
It might not have any. I like Perfect Circle seals, The meter oil into the guide. They are much more technical than a Umbrella type. They can be installed by putting a 2' piece of rope into the cylinder, and rotating it to hold the valves up while working on it. JimN
