fan pulley Super C
Beard
05-21-2008 10:14:32
How do you get fan pulley off crank shaft?
P and R Pete
05-21-2008 11:17:13
 Re: fan pulley Super C in reply to Beard, 05-21-2008 10:14:32
I did it like the I&T manual says, with a big-@ss bearing splitter and a two-jaw puller. You can barely see the puller tips.
third party image
Problem was, the end of my crankshaft was recessed and threaded, (not all of them are), nothing to put the point of the puller-shaft against, so I threaded in a bolt that stuck out beyond the pulley (which is a long sucker), and drilled a divot on the top of the bolt so the point of the puller wouldn't walk around.
Fair warning, mine was on there TIGHT, and I heated it with propane, (only heat I got) until it was too hot to touch, and then had to crank on the puller a lot harder than I thought was prudent, and it finally started moving with a loud *snap*, thought I'd broken something.
For future reference, here's how I got it back on, using a bottle jack.
third party image
Good luck.
Joe Kimbriel
05-21-2008 10:49:16
Heavy duty puller. Some folks made there own.
Do a search here.
