Friction or sawtooth throttle preference?
RedDogFarms
05-21-2008 13:33:17
Sawtooth lever has worn out on my H, has been welded a couple of times, wondering if I should go with a friction lever or stay with sawtooth?
BOBM25
05-22-2008 12:28:26
 Re: Friction or sawtooth throttle preference? in reply to RedDogFarms, 05-21-2008 13:33:17
Sawtooth for me. I'm a stickler for originality, though. I'm also in the habit of pushing down on the handle when throttling up so to avoid wear caused by dragging it across the teeth.
Chuck46
05-21-2008 20:01:55
Red, I have the notched on both the H and MD, definetly like it better than friction and they are an improvement over the sawtooth. Good luck, Chuck
jonnny2006
05-22-2008 23:13:55
 Re: Friction or sawtooth throttle preference? in reply to Chuck46, 05-21-2008 20:01:55
Chuck... The MD uses a compleatly diffrent setup.
Chuck46
05-23-2008 07:34:40
 Re: Friction or sawtooth throttle preference? in reply to jonnny2006, 05-22-2008 23:13:55
Jonnny, IH sold an improvement kit for the diesels that used the same notched throttle as the H and M. It is a lot better than the left hand uppercut that was standard.
onefarmer
05-21-2008 19:45:52
I prefer the sawtooth. I had a MW friction on my M for years and battled it slipping from WOT. Put the sawtooth on and it holds the setting forever.
I think it looks better with the original style too.
Vally Farm
05-21-2008 18:58:01
Sawtooth. Always know where to put it for PTO work, or any other common job. If it had a tach, mabe have a different answer. Mike
jonnny2006
05-21-2008 17:48:48
 friction s better in reply to RedDogFarms, 05-21-2008 13:33:17
The 1st thing i do to all my tractors is put a friction one on. The ones on ebay are better then the saw tooth type. I have 4 old saw tooth type. They are pretty much worthless. Seen them sell on ebay for less then 5 dollars. So they must not be rare.
CNKS
05-21-2008 19:53:15
 Re: friction s better in reply to jonnny2006, 05-21-2008 17:48:48
They aren't rare, IH used sawtooth until the end of production, possibly used notched toward the end. Notched was the replacement for the sawtooth. It does not slip. Still say the M&W looks clutzy.
CNKS
05-21-2008 17:22:37
Sawtooth, or notched. Throttle lever on the H/M, etc is unique, M&W friction makes them look like any old tractor. You don't need any more fine tuning than the saw tooth or the newer notched will give.
Red Mist
05-21-2008 17:05:08
Like sparkplug brand, it is a personal choice. mike
Steven f/AZ
05-21-2008 16:33:04
I prefer friction. The cheap knock-offs on eBay aren't as good as a genuine M&W, though.
Janicholson
05-21-2008 15:43:11
Friction is desirable. M&W Parts on farmalls do not detract from value. I find the tooth style too be temporary in function.. JimN
Zach Bouchard
05-21-2008 13:53:32
People say the friction throttle gives you more selection on RPM"s but I don"t think you really need it.
