Zenith Carburetors
Randy Trentham
05-21-2008 16:36:43
I have two Zenith updraft carbs. They have the round tags. There are semi-circles of numbers on each tag. One carb has 10748 and the other is 966 on the tags. These are the inner circle of numbers. I was told that they would fit a Farmall. Could someone help me with the correct application for these carbs? Thank you very much for your help.
MCD
05-26-2008 12:29:14
 Re: Zenith Carburetors in reply to Randy Trentham, 05-21-2008 16:36:43
10748 is a wisconsin carb. The other number is incomplete. There"s got to be an S or more digets to find out what it goes with.
Randy Trentham
05-26-2008 13:52:00
 Re: Zenith Carburetors in reply to MCD, 05-26-2008 12:29:14
The best that I can see other than 966 possibly is 2 4 . I can"t be sure but that is the best that I can see. Thanks for your help - I appreciate your help. Regards Randy T.
