serial number on right rail of M?
jonnny2006
05-21-2008 18:07:00
I saw a post on here that the serial number is also put on the right frame rail on M's. Is this true of any other models? I never noticed it. So if this is true there are three spots where there is a serial number. I take it it would match the one on the bell. Any info would be app. thanx
JayIHMan
05-23-2008 19:13:39
 Re: serial number on right rail of M? in reply to jonnny2006, 05-21-2008 18:07:00
I have S/N 854 and it has big numbers on side rail, no tag on bell housing but has holes for one.
RustyFarmall
05-21-2008 18:15:41
The serial number on the frame rail was only there on the '39s and maybe a few very early '40s. If the serial number is on the frame rail, there will NOT be a serial number tag on the clutch housing.
randy hall
05-21-2008 18:33:21
 Re: serial number on right rail of M? in reply to RustyFarmall, 05-21-2008 18:15:41
sorry rusty but only a very few '39 m's didn't have serial number tags. i have #691 and it has the holes in the clutch housing for the tag. a friend has #517 and it's clutch housing does not have the rivet holes for the tag. the big numbers stamped on the frame rails went into the thousands.
