replacement push rod for ih 340 (c135) engine
coovybird
05-21-2008 21:50:20
Hello all,
I am looking for replacements of a couple of bent push rods from my IH 340. Any ideas where I can track these down? I am rebuilding the engine.
Many Thanks
Dan
1fortyfanatic
05-22-2008 18:09:47
 Re: replacement push rod for ih 340 (c135) engine in reply to SuperA-Tx, 05-21-2008 21:50:20
I'm with rusty. I couldn't find rods for my 140, so I straightened the old ones gently and patiently. Working great and should be alright since I adjusted the valves correctly while I was in there.
Dave
kossuth
05-22-2008 08:18:44
 Re: replacement push rod for ih 340 (c135) engine in reply to coovybird, 05-21-2008 21:50:20
coovybird said: (quoted from post at 21:50:20 05/21/08) Hello all,
Many Thanks
Dan
I'll tell you this. Yeah you can straighten em BUT generally it is a bad idea. Pushrods are heat treated and generally when bent are not as strong the next time around as they were from the get go. You can get a new set of pushrods from a racing warehouse like Summit Racing or Jegs for about $25-$40 for a set of 16. Now, obviously you need to get the proper length and the proper diameter. Plus you can get custom lengths too (not sure on the price of custom lengths though) so you aren't limited to reusing something or buying new ones at $15 a crack.
RustyFarmall
05-22-2008 11:03:14
 Re: replacement push rod for ih 340 (c135) engine in reply to kossuth, 05-22-2008 08:18:44
The pushrods in these old tractor engines are NOT heat treated, except for the very ends where the wear occurs. I've straightened out pushrods from tractor engines and all of them are still going strong 10 years later.
RustyFarmall
05-22-2008 04:21:56
Unless those pushrods are seriously bent, you can straighten them. Lay them down on a hard, flat surface and gently strike them with a hammer. When you think they are straight, roll them across that flat surface, and if there is no wobble, you are done. If it still wobbles a bit, use the hammer some more. It'll last just as long as a new one.
PaulW_NJ
05-22-2008 03:53:09
I had a surprisingly hard time finding replacement rods for those bent on my 240. I found them from an IH dealer in PA (Hoober.com). New were $20 each, but they also sell used for $10.
