Loadstar 1600
Phlogiston
04-09-2000 18:09:36
I know this is not a truck forum, but I thought you guys could point me in the right direction. Does anybody know of a discussion group that I could ask some questions regarding an IH Loadstar 1600? It has not run in 4 years. I might try to get it going again. The price is right....free. Thanks in advance for all the help.
Phlogiston.
thaddeus333
10-26-2005 02:17:49
 Re: Loadstar 1600 in reply to Phlogiston, 04-09-2000 18:09:36
Hi,
I recently picked up a 76 1600 loadstar with a 14 box on the back. Truck runs good but needs power steering. Anyone know where I might come across a full set up. I have been told that any year up to 1980 should suffice. Drop me an emial if you have one or know where to get one. thanks
Rob
08-28-2002 22:06:02
Me and a buddy of mine got a '71 loadstar for free . The flatbed was rotted through and it was really rusty . The engine would only fire over if you put gas straight into the carb . The problem was the electric fuel pump was shot and had no shut off , so it ran if the batery was on but not the engine . The thing was flooding so I just put a toggle switch on the dash to turn on the gas when I drive it . The truck is a beauty and runs terific . The truck only has 85,000 miles on it but it has much more hours on the engine due to the pto which operates the boom . Even though the truck is old and has lots of hours it still runs great .
adam
05-23-2002 06:15:57
I have a 1800 loadstar and it sits over the winter to start it in the spring I charge the battery and dump gas in the carb and she fires right off
F14
04-10-2000 03:12:13
 Re: Re: Loadstar 1600 in reply to Ludwig, 04-09-2000 18:40:34
A local mechanic that has been working on trucks since the 50's tells me that IHC's, especially with the 345 engine, are very sensitive to over-revving, and have a nasty tendency to twist off the drive quill on the oil pump, leading to their demise. Other than that, they are bullet-proof.
