TD 14 CRAWLER
Nick
04-09-2000 20:12:24
I need two radiator core caskets for a TD 14 Crawler. Top and Bottom. Can anyone help?
cameron
10-01-2003 08:33:34
 Re: TD 14 CRAWLER in reply to Nick, 04-09-2000 20:12:24
looking for ring and pinion gear for a 1950 IH td 14a crawler serial number ends with 288t700
Paul Fox
04-10-2000 03:05:45
If the radiator on a TD-14 is similar to that of early unstyled Farmalls like the F14 or F20, it's not terribly difficult to make one. I used the top and bottom tanks to make patterns and cut them out of some rubber-impregnated cork gasket material. Haven't had a problem with them leaking.
D. Beatty
06-20-2001 18:06:22
 Re: Re: TD 14 CRAWLER in reply to Paul Fox, 04-10-2000 03:05:45
I had the same problem of gaskets not being available, and in desperation just used a truck tire innertube. Since the rad operates at zero pressure, this had held on mine for the last 21 years !
