Bolt pattern and cyl. head torque specs.
DAN
04-12-2000 19:35:50
I am trying to find the cyl. head bolt pattern and head bolt torque specs. for a FARMALL model- A. I need to replace the head gasket and need to know the torque specs. Thanks for any help-- DAN
david
11-08-2003 10:59:24
 Re: Bolt pattern and cyl. head torque specs. in reply to DAN, 04-12-2000 19:35:50
i need head torque specs for ford 5610 tractor and pattern
Justin
04-13-2000 06:37:35
Start in the center and work out in pattern. The final torque id 65lbs.
Phil Auten (TX)
04-13-2000 13:14:17
 Re: Re: Bolt pattern and cyl. head torque specs. in reply to Justin, 04-13-2000 06:37:35
That should read "work out in a spiral pattern".
65 ft/lbs sounds correct. Be sure to work up to that in three steps, starting at about 45 ft/lbs, then 55, then 65. Retorque after running the engine for a couple of hours at operating temp and cooling down. Then again after about another 10 hours of running time. This will keep your head gasket from being blown by a bolt/nut that works itself loose. Also, lubricate the bottoms of the bolt heads and the nuts so they won't interfere with getting the proper torque.
Have fun,
Phil
