VanSickle Paint??
Kenneth Fass
04-18-2000 10:26:20
Has anyone used VanSickle paint? I'm wondering if their "Case IH Red" is a match for Farmall, or is it strictly the color used in current production?
-- Ken
Joe Tilton
03-03-2004 13:22:21
 Re: VanSickle Paint?? in reply to Kenneth Fass, 04-18-2000 10:26:20
My experience is with the JD green. To avoid an extended drying time, I used a hardner. The color was very good. Application was via spray in full-size gun. My touch-up gun didn't do as good a job, perhaps because of finer spray. Consider more thinner than recommended. Definately use a hardner.
rodger
04-18-2000 19:14:49
Hello,
I too thought it was a little light in tone. In fact, I started to use it and then changed to a product sold by Tractor Supply, which I believe is made by Best Paint Company. I thought it was a darker, more IH red that I remembered. I wasn't doing a perfectionist refinish, but wanted something close.
I paid $18.99/gal. in Kansas
The Red
04-18-2000 11:30:35
Kennith I use the Van Sickle all the time and I think it applies well and holds up quite well. The color, however, is slightly lighter in color than the IH 2150 Rouge.
A gallon runs around $22 in Indy and the spray cans run $2.80.
Kenneth Fass
04-19-2000 12:51:13
 Re: Re: VanSickle Paint?? in reply to The Red, 04-18-2000 11:30:35
Thanks Red. I suspected it might be the lighter shade. (Prices sound good - I need to start shopping where you do) -- Ken
The Red
04-19-2000 14:04:31
 Re: Re: Re: VanSickle Paint?? in reply to Kenneth Fass, 04-19-2000 12:51:13
Thrifty farm store in Brownsburg, IN, just west of Indianapolis. This is a true farm store with stuff disorganized and a cat to pet as you walk in! :)
Farmboy
04-18-2000 19:04:17
I finished my F-14 off last summer with Vajn Sickle. Sprayed on with Heated HVLP turbine and turned out really well....the color is very close if not exact. I don't know how it wears against sunfade since it's usually kept inside. Good Luck, Farmboy
