Order Farmall Cub Parts Online
Cub Hydraulic Pump
Scott
04-18-2000 10:39:54
There is a slight groove in the drive shaft of the hydraulic pump on my '48 cub where the drive shaft contacts the the seal. Is this groove supposed to be there?
JLE
04-21-2000 17:38:34
 Re: Cub Hydraulic Pump in reply to Scott, 04-18-2000 10:39:54
Cub hyd pump uses an O-ring for the seal, new ring will hold for a while.
CLARK
04-18-2000 14:18:00
NO SCOTT, THE GROOVE IN THE HYDRAULIC PUMP SHFT IS NOT SUPPOSED TO BE THERE.THE GROOVE IS CAUSED BY THE OLD SEAL THAT WAS MADE OUT OF LEATHER.I ASSUME THAT YOUR REPLACEING THE SEAL BECAUSE OF HYDRAULIC FLUID LEAKING INTO THE CRANKCASE.IF YOU REPLACE THE SEAL IT WILL STILL LEAK BECAUSE OF THE GROVE IN THE SHAFT, YOU WILL HAVE TO REPLACE THE SHAFT TOO.
ray
04-18-2000 15:37:09
 Re: Re: Cub Hydraulic Pump in reply to CLARK, 04-18-2000 14:18:00
it shouldnt be necessary to replace the shaft you could try a speedy sleeve or try adif mfg seal chances are seal willride in a diff place on shaft
Barbara C. Anderson
09-08-2006 17:46:16
 Re: Re: Re: Cub Hydraulic Pump in reply to ray, 04-18-2000 15:37:09
Just replaced a hose on my 1650. Lost the fluid. Where/how do I refill the hydraulic fluid?
