I.H. 3414 questions.
Doug
04-24-2000 08:34:33
I have a 72' International 3414 diesel. What horsepower is this engine rated at? What's wrong when I get anti-freeze out of the bottom of the oil pan? It isn't enough to turn the oil milky but there is evidence of green anti freeze when I first pop the drain plug. Finally, where can I find a 3 point hitch rig for this thing. It has a backhoe on it now. I thought I saw an interchangeable 3 point kit somewhere in life.
Harold H
04-24-2000 17:43:23
 Re: I.H. 3414 questions. in reply to Doug, 04-24-2000 08:34:33
The 3414 has the same 154 cu inch engine as the B-414 which tested 32.57 db hp and 35.99 pto hp. I don't have the engine hp rating but it would be around 40. You probably have a leaking head gasket to get the antifreeze in the oil although it could be something more serious. Your 3414 probably does not have a rockshaft since it was equipped with a backhoe, so you cannot put a IHC hitch on it but will have to install a aftermarket 3 point hitch. If yours does have a rockshaft, they were available but not common, on the 3414, the three point hitch from a B-414, I-424, I-444, and several later models or some current Mahindra models should fit.
Harold H
