Super A not oiling rocker arms
Grady
04-28-2000 09:59:23
How does oil get to rocker arms? I pulled valve cover to adjust valve clearance only to find it dry. There looks to be an oil passage in the center mount of the rockers but no passage in the head. Gauge is showing good pressure and it is full of oil.
gn
04-28-2000 12:59:41
 Re: Super A not oiling rocker arms in reply to Grady, 04-28-2000 09:59:23
Make sure the stud and all the oil holes are aligned with each other too...gn
p
04-28-2000 11:39:45
The center stud that the rocker assembly bolts to is hollow. The oil comes up through the stud and then is sent on to the rocker. It sounds as if this hole is plugged with grime...
Les Repair
04-28-2000 17:22:43
 Re: Re: Super A not oiling rocker arms in reply to p, 04-28-2000 11:39:45
Someone may have replaced the center stud with the wrong one.
