140--coil too hot..?
gn
05-30-2000 10:50:15
I hope someone can answer this strange question. I rebuilt my 140, and rewired it, converting it to 12v. Everything is working just fine, she charges great, etc. Except...if you put your hand on the coil (it has a distributor), it's almost too hot to touch. This is with the original 6v coil. I bought a Chrysler type ballast resistor, and put that in line. I bought a 12v coil and that even feels real hot. I just feel like I'm gonna be a long way from the barn some day and something's gonna go up in smoke.. any suggestions.??
ltf in nc
05-30-2000 19:25:49
 Re: 140--coil too hot..? in reply to gn, 05-30-2000 10:50:15
The voltage to the points is too high. With the points closed the voltage should be 5 to 7 volts.
MikeK
05-30-2000 12:09:11
Go to Auto Zone and tell them that you want a 12V coil for use w/out an external resistor.It will work just fine..... .....Mike
gn
05-30-2000 12:20:50
 Re: Re: 140--coil too hot..? in reply to MikeK, 05-30-2000 12:09:11
The 12v coil that I have IS the type for use without an external resistor...that's the problem. The only thing I can think is that I asked for that type, and they gave me the other at the parts store...it's happened before...ya can't tell by looking at them..thanks...gn
