Paint for 460
Gorilla
07-03-2000 06:57:51
Where is the best place to get paint for a farmall and what is the best kind to use. I have a super m that was painted before I got it and now its faded & "pink". Im starting to rebuild a 460 and dont want to have the same problem. Also any ideas you have on prep & primer would be appreciated. Thanks,
Phil Auten (TX)
07-03-2000 12:41:21
 Re: Paint for 460 in reply to Gorilla, 07-03-2000 06:57:51
Gorilla,
The IH 2150 red seems to hold up pretty well, but it works a lot better if a hardener is used with it. Less sun fading (a big problem here in Central Tx.).
Phil
the tractor vet
07-04-2000 17:52:49
 Re: Re: Paint for 460 in reply to Phil Auten (TX), 07-03-2000 12:41:21
use the ih 2150 red like the orther guy sad also use ih primer cub cadet white and du ponit 77s hardner
sammy the RED
07-03-2000 08:40:35
IH-2150 Red, IH-Aluminum for the rims and PPG 8665 White
tommy w
07-03-2000 22:24:57
 Re: Re: Paint for 460 in reply to sammy the RED, 07-03-2000 08:40:35
what ever you do do not use ih brand paint it is pure junk .have your local ppg rep mix you some ppg delstar or ppg concept. these paints use a toxic catilast so buy a new 3m paint mask i have the ppg codes as we paint tractors as our business email me at twwhowdy@aol if you cant get the codes as for the primer use a good epoxy primer ppg is the dp line
the tractor vet
07-07-2000 19:02:13
 Re: Re: Re: Paint for 460 in reply to tommy w, 07-03-2000 22:24:57
i said once before my buddy and ihave painted more tractor that have been on more video trading cards calanders and on allfarmall we use case ih 2150 red over the ih primer my owen smta was on the 94 red power video and also on the cover of ohio fast line so i think i know what iam talking about.
Jon
07-03-2000 07:26:52
I am going to use CaseIH 2150 red for my Farmall 400 that is available at any CaseIH dealer. I am also going to use CaseIH primer. I have heard that these are good paints to use. Hope this helps.
