706 can't find reverse
Paul Frey
08-09-2000 05:55:45
The 706 will grind reverse but won't engage. What needs to be adjusted?
Charles Powell
06-30-2003 18:07:48
 Re: 706 can't find reverse in reply to Paul Frey, 08-09-2000 05:55:45
It probably needs a new reverse driven gear if it won't engage. We recently replaced this gear in our tractor because the parking brake puts a paw into the gear to lock it. Ours was still in gear when the parking paw was engaged and stripped every tooth off of the gear.
Jim
08-09-2000 11:05:50
Most of the time the top cover is worn out in reverse pivot arm.
Mudcat49
08-09-2000 07:36:54
There is a plate on the side of the transmission where you can get in there and see if the reverse shifting fork is ok.
