Leak at final drive
Gorki
10-20-2000 09:29:03
My 140 drips fluid down at the bottom of the final drive housings. This is below where the fast-hitch bars mount on each side. Is this a difficult fix?
Someone told me there are no gaskets here, just a machined fit. THis area is really out in the open and would be subject to a lot of possible damage by going over rocks and stumps and everything. I'm afraid I got some damage to the parts on the bottom if that is the case. How does it come off..? A couple of bolts maybe? Is it a stamped bowl to contain lube.? thanks ya'll
Gorki
Jim Becker
10-20-2000 10:50:15
 Re: leak at final drive in reply to Gorki, 10-20-2000 09:29:03
You could have a leak where the pan bolts to the final drive housing or it could be axle seals. If at the pan, it is assembled with a cork gasket. The manual says the fill plug is also the oil level, but that leaves oil constantly against the pan gasket. You can leave the level lower, so it isn't against the gasket but the bull gear is still running in oil. The oil will circulate but the leakage may stop.
