IH Tractor WD9?
Super WD9?
Donn
01-14-1999 19:56:15
Help? Need to identify exactly what I have. Seeking pictures or books relating to this particular tractor. Any advise on where to find identifying marks, etc., please let me know. TIA, Donn
john r
01-16-1999 11:28:51
 Re: IH Tractor WD9? - Super WD9? in reply to Donn, 01-14-1999 19:56:15
donn a super wd9 will have ih emblem on the grill,rear wheels have brackets riveted to rim and bolted to wheel,disk brakes and a350 engine
JW
01-15-1999 07:24:02
Does this tractor have disc brakes or the old band style brakes? If it is disc, it is probably super. Do you have the ID plate? If it is on there, a super will say SWD9 a non super will just say WD9.
I hope some of this helps.
Donn
01-15-1999 20:27:37
 Re: Re: IH Tractor WD9? - Super WD9? in reply to JW, 01-15-1999 07:24:02
Haven't been able to find any ID. the only thing I know about this tractor is it starts on gas then switches to diesel and has a hand clutch.
Can you suggest any books that will deal with SWD9 or WD9?
TIA - Donn
rkheath@coffey.com
JW
01-19-1999 10:54:55
 Re: Re: Re: IH Tractor WD9? - Super WD9? in reply to Donn, 01-15-1999 20:27:37
the plate should be in framewark of the gas tank support. It may have been lost somewhere along the way. You may be able to find the serial number on the block of the engine. If you find a book that has serial numbers in it, look under the swd9 and the wd9 and see if that helps. Assuming it is the original engine, the number on the block should be the same as the tractors serial number.
Is there any reminents of the wd-9 sticker on the front of the hood? If the sticker has a white backgroundwith red letters, the tractor is a super, if it has a red background with white letters, it is not.
Good Luck
