super c 12 system
steven in tn
04-02-2013 13:17:45
third party image
switched neighbors supper c over to 12 volt.
ever thing works like it should except the Ballast Resistor is getting hot when you cut the ing. switch on. go ahead and crank the tractor and run, and the resistor still gets warm.
what could be causing this?
the pic is what i went by.
stanhoist
04-02-2013 17:26:15
 Re: super c 12 system in reply to steven in tn, 04-02-2013 13:17:45
6 or 12 volt coil?
steven in tn
04-02-2013 17:18:16
ok guys, thanks for the help.
1 more ? about the coil, what will happen to the 6 volt coil if used instead of 12 volt coil.
Janicholson
04-02-2013 17:19:56
 Re: super c 12 system in reply to steven in tn, 04-02-2013 17:18:16
If you use a ignition ballast resistor in the lead from the switch to the coil it will just be fine. Jim
teddy52food
04-02-2013 17:05:11
The resistor changes that energy to heat so it doesn't burn out the coil.
Janicholson
04-02-2013 13:38:41
If it is not hot, it is not working. All is well. Jim
IAtractorKid
04-02-2013 13:34:01
Perfectly normal for them to get hot. Its a resistor, that's why you don't mount them near anything flammable.
