Question on Coil wire hook up on 12 v conversion
cbrown
04-03-2013 09:06:32
farmall h 12v conversion, 2 questions should it be negative or positive ground, and what wire go to + and - with ground hookup, thanks alot
John T
04-03-2013 12:01:06
 Re: Question on Coil wire hook up on 12 v conversion in reply to cbrown, 04-03-2013 09:06:32
Most off the shelf at auto store Alternators are NEGATIVE GROUND although as noted it is possible to have one made for Positive so hook it up accordingly and for Neg ground (if that's what you have) the coils + receives voltage from the Ign switch while its - wires to the distributor. If it had an ammeter and it was originally POS ground but you switched over to NEG ground the ammeter leads need reversed or it will read bass ackwards lol
John T On the road headed back North to Indiana
cbrown
04-03-2013 11:19:39
ok i got it fugured out, and she finally runs, thanks
cbrown
04-03-2013 09:51:22
delco alternator, has a pole on it that says bat so i ran that to battery switch, i have it negative ground, and i will hook up distributer wire to neg, and pos pole to switch correct?
David G
04-03-2013 09:22:32
Old has it, BUT make sure the alternator is what you think. You can order special polarity alternators, and they WILL smoke if hooked up wrong.
old
04-03-2013 09:14:49
Is it a generator or an alternator 12 volt system??? If an alternator you have about a 99% chance it is - ground and if you hook it up + you will let the smoke out the moment you hook up the battery. As for the coil you always hook the same side of the coil as your ground so if you do a - ground the - goes to the distributor
