560 D year??
Gene
01-17-1999 03:20:29
Just got a 560 D home, and trying to find out what year it is and the SR # plate is missing, But on the wide front end is a ID plate thar reads: Du560 50 Du13559 and was made by SCHWARTZ CO. could the last two numbers mean it was made in 1959, and that the tractor is a 59. or can the motor # be traced back to the tractor year ??? Thanks for the help Gene
Wayne
01-17-1999 14:35:20
 Re: 560 D year?? in reply to Gene, 01-17-1999 03:20:29
Get some casting #'s of the trans. and diff. case and post them here somebody can help you then Schwartz made front ends for many brands The tag on the front end will mean nothing as to year of tractor. Engine block # can be checked also
Gene
01-17-1999 19:01:02
 Re: Re: 560 D year?? in reply to Wayne, 01-17-1999 14:35:20
Thanks wayne Where is the motor number located??
Alvin
01-21-1999 00:34:31
 Re: Re: Re: 560 D year?? in reply to Gene, 01-17-1999 19:01:02
That year sounds about right . We got ours new in 1960 , still have it .. does any one want it?
Grady McFarland
08-25-2003 17:44:43
 Re: Re: Re: Re: 560 D year?? in reply to Alvin, 01-21-1999 00:34:31
Where do you live and what do you want for the 560 you purchased in 1960?
