Order Farmall Cub Parts Online
Cub timing probs....
'Bandit'
12-29-2000 17:38:41
I have an 49 Cub. About 12 yrs ago i had it converted from a magneto to a distributor, and ever since then every year the timing goes out 2 or more times. It is no problem to fix, but it is a pain. Does anyone have any idea why? or what i should look at?
Thanks...
PETERC
12-31-2000 09:27:33
 Re: Cub timing probs.... in reply to 'Bandit', 12-29-2000 17:38:41
if distributor hold down is not coming loose you might want to look at the gear on the dist drive for looseness or damaged teeth also dist shaft bushing. hope this helps
