Carb type on TEA 2085
rod
10-24-1999 06:01:23
Looks like my carb needs a rebuild it has number 24t 2 on it and is on 52 TEA 20 anyone know what type this is and where is a good place to get a kit.
rod
jim collacott
11-12-2001 04:33:06
 Re: Carb type on TEA 2085 in reply to rod, 10-24-1999 06:01:23
I got a kit at Durham East Farm Supply. He had 200 MADE UP SPECIAL. The carb company is out of business. Kit was $75 Canadian but now the 2085 runs like a charm. The throttle butterfly rod gets too worn and allows extra air in and can't be idled down properly. Call me at 905-644-5466 at Oshawa, Ontario, Canada.
Aaron
01-18-2000 01:49:38
Rebuild kits are unavailble if it is a zenith, and repacements cost $150, so either try to make do or you can get a newer model cab but it requires an adapter.
Greg
11-06-1999 19:49:56
You have the Zenith carburetter on that tractor. If you have a Massey Ferguson dealer in your area they may have the kit you require. The Zenith is a very simple unit which I cleaned with carb cleaner and 100psi air compressor and whittled a gasket from gasket paper. It works fine and it didn't cost nuthin'.
