Sure seals-where to buy?
NCtim
02-16-2002 13:37:26
I've just pulled off my brake drum because my left brake isn't working and it's coated with oil. I guess I may as well replace the shoes and seals now.
I've got a 1949 TEA-20. And while I'm waiting on some ignition parts I figure I may as well fix this stuff, too.
Where can I purchase the Sure Seals and related parts I'd like to just order off of the internet if I can.
Tim
RICK
02-16-2002 20:25:46
 Re: sure seals-where to buy? in reply to NCtim, 02-16-2002 13:37:26
ive heard from some people that the sure seals dont always last very long. you may want to consider changing the main seal behind the axle bearing which will last for years it cost me 105.oo dollars about a month ago. just my opinion do your own searching and go with it
NCtim
02-17-2002 12:53:28
 Re: Re: sure seals-where to buy? in reply to RICK, 02-16-2002 20:25:46
How hard was this? My manual says it's pretty difficult because you have to remove the collar that holds the bearing on. The collar is a shrink fit and must be chiseled off and then replaced. Sounds like a lot of hard work to me. Was the 105.00 just for the parts?
Tim
RICK
02-18-2002 18:24:36
 Re: Re: Re: sure seals-where to buy? in reply to NCtim, 02-17-2002 12:53:28
all i had to do was pull out each axle and send it to the local mf dealer where he did all the work installing the new seals. i picked them up when they were done and put them back in the tractor.i think it was about 45 dollars for labor id have to dig out the bill to be sure.
